Hello I thought one of the features with JAMF and iOS 11 was to allow devices to have their OS remotely updated. When I select a device this is on iOS 11 and I choose Management, there is not a feature to upgrade to iOS 11.0.1... Am I missing something?
Page 1 / 1
Unfortunately, you can only do this for groups of devices. You have to select a group, Click Action at the bottom, Send Remote Commands, Update iOS Version.
not seeing it.
You can do it on single devices as well by just searching the device name and yes its not a management command. You search for the device or groups and at the bottom there is an "actions" tab right next to "export"
