Logout After 1 Min - Login Window Config - Not Working
If i have this profile applied on top of another Login window configuration profile will it still work? As of now it will not log out with no programs running.
I have had trouble with multiple config profiles managing the same plist in the past. When I tried it, only the first one applied.
I've seen lots of people have trouble setting this.
You can log users out with this command osascript -e 'tell application "loginwindow" to «event aevtrlgo»'. You can check the idle time with expr $(ioreg -c IOHIDSystem | awk '/HIDIdleTime/{ rec=$NF } END{ print rec }') / 1000000000.
Between the two you could put that into some kind of policy.
There's some more discussions on the topic here: https://jamfnation.jamfsoftware.com/discussion.html?id=11254
