We are distributing a web clip via a profile and have created a our own icon for it so that it can be easily located on the iPad. The web clip distributes with no issues and shows up with the icon we designed. However, once the web clip is launched, it changes the web clip icon on the iPad to the website icon and removes the icon we created.
We have other web clips set up the same way that don't do this.
Is there any way to prevent the icon from changing once it is launched?
We are using a web instance of Jamf Pro v 10.0.0-t1508873342
Any assistance you can provide to resolve this issue would be greatly appreciated.
