I've been working on setting up 802.1x using profiles -I -F
On some machines, I'm noticing the mobileconfig is not creating the com.apple.network.eap.user.identity.wlan.ssid.SSIDNAMEHERE in keychain. On others, it gets created and connects immediately.
If I do a security get-identity-preference it returns a value in terminal and shows the appropriate certs being assigned, but won't connect to wifi.
Seems like doing the below works on ~70% of machines. Others are failing, or prompt the user to enter their password to access the keychain. Does anyone know why some don't require keychain passwords and some work flawlessly?
