Is it possible to use casper to dual boot Snow Leop and Lion?
Or do I need to manually install one?
John Wojda
Lead System Engineer, DEI & Mobility
3333 Beverly Rd. B2-338B
Hoffman Estates, IL 60179
Phone: (847)286-7855
Page: (224)532.3447
Team Lead DEI: Matt Beiriger
<mailto:mbeirig at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.>
Team Lead Mobility: Chris
<mailto:cstaana at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.> Sta
Ana
Mac Tip/Tricks/Self Service & Support
<http://bit.ly/gMa7TB>
"Any time you choose to be inflexible in your approach to an
unpredictable project you are already building failure into your plan"
You can deploy both to a single machine on separate partitions. I have 5 or 6 running that way
Todd Ness
Technology Consultant/Non-Windows Services
Americas Regional Delivery Engineering
HP Enterprise Services
Do I just run them through twice?
John Wojda
Page:  (224)532.3447
Team Lead Mobility: Chris Sta Ana
"Any time you choose to be inflexible in your approach to an unpredictable project you are already building failure into your plan"
Partition, name, image, all in one shot.
asr scripts to block copy the images to each partition
