Rebooting to a blinking ? icon
  • September 21, 2009
  • 19 views
After imaging some new all-white MacBooks, at restart they are booting up to
a blinking ?/folder icon?
What might be causing this to happen?
Jim Frye
District Technology Coordinator
Upper Sandusky E.V. Schools
Upper Sandusky, OH 43351
419-989-9895
**Note new email address ending w/ @usevs.org
Forum|alt.badge.img+31
that is a sign that it cannot find bootable material, typically a bad hard drive. You can try to do a low level format from an OS X disk to see if the drive is still good (but not readable by EFI) and if it fails the drive may be bad.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
blackberry: 913-449-7589
office: 913-627-0351
Jim,
What OS version did the the new MacBooks ship with and what OS version are
you imaging with? Do you already have MacBooks of this type in production?
Could be hardware failure as mentioned but considering that there is the
same effect with multiple machines and the same process applied and assuming
they booted and worked out the box I think it might be image.
James Alcasíd, ACSA | VeriSolv Technologies
Department of Veterans Affairs | Enterprise Infrastructure Engineering
470 L'Enfant Plaza Suite 3100, Washington DC 20024
Note:
This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mis-transmission. If
you receive this message in error, immediately delete it and all copies of
it from your system, destroy any hard copies of it and notify the sender.
You must not, directly or indirectly, use, disclose, distribute, print, or
copy any part of this message if you are not the intended recipient. Any
views expressed in this message are those of the individual sender, except
where the message states otherwise and the sender is authorized to state
them to be the views of any such entity.
Sometimes, it is as simple as forgetting to check the "Boot to VOlume" in the imaging process, or that the final run script did not run. I would just format the HD and then rerun your image process.
Karl H. Hehr
Technology/Curriculum Director
South Hamilton CSD
www.s-hamilton.k12.ia.us
515.827.5418 (W)
515.209.9767 (C)
515.827.5368 (F)
Luddite by Degrees
1) Anything that is in the world when you're born is normal and ordinary and is just a natural part of the way the world works.
2) Anything that's invented between when you're 15 and 35 is new and exciting and revolutionary and you can probably get a career in it.
3) Anything invented after you're 35 is again the natural order of things --- Douglas Adams
