Hi guys
We have the really weird situation that suddenly many OS X machines with several clients start to act weird and when trying to restart boot into recovery mode. The system that was installed on the main drive is defective and and the only troubleshooting step that helped so far was restoring the machine.
When looking at the system log the problem appears for the first time shortly after this entries:
Feb 8 06:28:21 iMac-225-C16-2.local nbagent[10168]: XPC Activity invoked with state=2 Feb 8 06:28:21 iMac-225-C16-2.local nbagent[10168]: NoticeboardUpdateOperation: Cancelling poll operation because Check for Updates Automatically is disabled in App Store prefs Feb 8 06:28:23 iMac-225-C16-2.local WindowServer[2009]: CGXDisplayDidWakeNotification [855555200113266]: posting kCGSDisplayDidWake Feb 8 06:28:23 iMac-225-C16-2.local WindowServer[2009]: handle_will_sleep_auth_and_shield_windows: Deferring. Feb 8 06:28:35 iMac-225-C16-2.local SecurityAgent[2013]: User info context values set for >power Feb 8 06:28:35 iMac-225-C16-2.local loginwindow[2008]: Login Window - Returned from Security Agent Feb 8 06:28:36 iMac-225-C16-2.local shutdown[92409]: halt by _usbmuxd: Feb 8 06:28:36 iMac-225-C16-2 kernel[0]: Kext loading now disabled. Feb 8 06:28:36 iMac-225-C16-2 kernel[0]: Kext unloading now disabled. Feb 8 06:28:36 iMac-225-C16-2 kernel[0]: Kext autounloading now disabled. Feb 8 06:28:36 iMac-225-C16-2 kernel[0]: Kernel requests now disabled. Feb 8 06:28:36 iMac-225-C16-2.local shutdown[92409]: SHUTDOWN_TIME: 1454909316 93358 Jan 1 01:00:09 localhost bootlog[0]: BOOT_TIME 978307209 0 Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.appstore" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl". Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd". Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.authd" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.bookstore" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.eventmonitor" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.install" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.iokit.power" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.mail" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.MessageTracer" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.performance" claims selected messages. Those messages may not appear in standard system log files or in the ASL database. Jan 1 01:00:24 localhost syslogd[19]: Configuration Notice: ASL Module "com.apple.securityd" claims selected messages. Those messages may not appear in standard system log files or in
Really weird is the fact that the machine changes the date to Jan 1st. After restarting the date is again correct but we have an endless list of errors:
Feb 8 08:10:25 iMac-225-C16-2.local loginwindow[42]: ERROR | -[Application hardKill:] | Application hardKill returned -600 Feb 8 08:10:26 --- last message repeated 1 time --- Feb 8 08:10:26 iMac-225-C16-2.local jamf[965]: open on /Library/Application Support/JAMF/tmp/anykey IT Client Logout: File exists Feb 8 08:10:34 iMac-225-C16-2.local cfprefsd[453]: cfprefsd failed to open /Users/schueler/Library/Preferences/com.microsoft.Word.plist.iDoVoFl for writing. Cancelling attempt to save preferences. Errno was 2 Feb 8 08:10:52 iMac-225-C16-2.local com.apple.usbmuxd[26]: stopping. Feb 8 08:10:52 iMac-225-C16-2.local com.apple.usbmuxd[1028]: log filter changed from 4 to 6 Feb 8 08:10:52 iMac-225-C16-2.local com.apple.usbmuxd[1028]: usbmuxd-364 on Aug 4 2015 at 14:36:18, running 64 bit Feb 8 08:16:58 iMac-225-C16-2.local com.apple.kextd[12]: Rescanning kernel extensions. Feb 8 08:17:11 iMac-225-C16-2 kernel[0]: Resetting IOCatalogue. Feb 8 08:17:11 iMac-225-C16-2.local com.apple.kextcache[1035]: rebuilding /System/Library/Caches/com.apple.kext.caches/Startup/kernelcache Feb 8 08:17:17 iMac-225-C16-2.local com.apple.kextcache[1037]: / locked; waiting for lock. Feb 8 08:17:21 iMac-225-C16-2.local coreservicesd[69]: Posted system configuration change notification Feb 8 08:17:51 --- last message repeated 2 times --- Feb 8 08:18:11 iMac-225-C16-2.local com.apple.kextcache[1039]: / locked; waiting for lock. Feb 8 08:18:48 iMac-225-C16-2 com.apple.launchd.peruser.503[299] (com.apple.ReportCrash[1041]): Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory Feb 8 08:18:48 iMac-225-C16-2 com.apple.launchd.peruser.503[299] (com.apple.ReportCrash[1041]): Job failed to exec(3) for weird reason: 2 Feb 8 08:18:50 iMac-225-C16-2.local com.apple.kextd[12]: Warning: /System/Library/Extensions: No such file or directory Feb 8 08:18:50 iMac-225-C16-2.local com.apple.kextd[12]: Can't stat source folders for cache file /System/Library/Caches/com.apple.kext.caches/Directories/System/Library/Extensions/KextIdentifiers.plist.gz. Feb 8 08:18:50 iMac-225-C16-2.local com.apple.kextd[12]: Rescanning kernel extensions. Feb 8 08:18:50 iMac-225-C16-2 com.apple.launchd[1] (com.apple.ReportCrash.Root[1043]): Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory Feb 8 08:18:50 iMac-225-C16-2 com.apple.launchd[1] (com.apple.ReportCrash.Root[1043]): Job failed to exec(3) for weird reason: 2 Feb 8 08:18:50 iMac-225-C16-2 kernel[0]: Resetting IOCatalogue. Feb 8 08:18:50 iMac-225-C16-2.local com.apple.kextd[12]: Can't stat /System/Library/Extensions - No such file or directory. Feb 8 08:19:29 iMac-225-C16-2.local com.apple.kextcache[1036]: IOSCSIParallelFamily.kext is invalid; can't resolve dependencies. Feb 8 08:19:29 iMac-225-C16-2.local com.apple.kextcache[1036]: IOPCIFamily.kext is invalid; can't resolve dependencies. Feb 8 08:19:29 iMac-225-C16-2.local com.apple.kextcache[1036]: PromiseSTEX.kext is missing dependencies (including anyway; dependencies may be available from elsewhere) Feb 8 08:20:24 iMac-225-C16-2.local com.apple.kextcache[1036]: IOSCSIParallelFamily.kext is invalid; can't resolve dependencies. Feb 8 08:20:24 iMac-225-C16-2.local com.apple.kextcache[1036]: IOPCIFamily.kext is invalid; can't resolve dependencies. Feb 8 08:20:24 iMac-225-C16-2.local com.apple.kextcache[1036]: HighPointRR.kext is missing dependencies (including anyway; dependencies may be available from elsewhere) Feb 8 08:20:44 iMac-225-C16-2.local com.apple.kextcache[1036]: IOSCSIParallelFamily.kext is invalid; can't resolve dependencies. Feb 8 08:20:44 iMac-225-C16-2.local com.apple.kextcache[1036]: IOPCIFamily.kext is invalid; can't resolve dependencies. Feb 8 08:20:44 iMac-225-C16-2.local com.apple.kextcache[1036]: HighPointIOP.kext is missing dependencies (including anyway; dependencies may be available from elsewhere) Feb 8 08:20:52 iMac-225-C16-2.local com.apple.kextcache[1036]: IOSCSIParallelFamily.kext is invalid; can't resolve dependencies. Feb 8 08:20:52 iMac-225-C16-2.local com.apple.kextcache[1036]: IOPCIFamily.kext is invalid; can't resolve dependencies. Feb 8 08:20:52 iMac-225-C16-2.local com.apple.kextcache[1036]: CalDigitHDProDrv.kext is missing dependencies (including anyway; dependencies may be available from elsewhere) Feb 8 08:21:03 iMac-225-C16-2.local com.apple.kextcache[1036]: IOSCSIParallelFamily.kext is invalid; can't resolve dependencies. Feb 8 08:21:03 iMac-225-C16-2.local com.apple.kextcache[1036]: IOPCIFamily.kext is invalid; can't resolve dependencies. Feb 8 08:21:03 iMac-225-C16-2.local com.apple.kextcache[1036]: ATTOExpressSASRAID2.kext is missing dependencies (including anyway; dependencies may be available from elsewhere) Feb 8 08:21:57 iMac-225-C16-2.local com.apple.kextcache[1036]: IOSCSIParallelFamily.kext is invalid; can't resolve dependencies. Feb 8 08:21:57 iMac-225-C16-2.local com.apple.kextcache[1036]: IOPCIFamily.kext is invalid; can't resolve dependencies. Feb 8 08:21:57 iMac-225-C16-2.local com.apple.kextcache[1036]: ATTOExpressSASHBA2.kext is missing dependencies (including anyway; dependencies may be available from elsewhere) Feb 8 08:22:05 iMac-225-C16-2.local com.apple.kextd[12]: Warning: /System/Library/Extensions: No such file or directory Feb 8 08:22:05 iMac-225-C16-2.local com.apple.kextd[12]: Can't stat source folders for cache file /System/Library/Caches/com.apple.kext.caches/Directories/System/Library/Extensions/KextIdentifiers.plist.gz. Feb 8 08:22:05 iMac-225-C16-2.local com.apple.kextd[12]: Rescanning kernel extensions. Feb 8 08:22:05 iMac-225-C16-2 kernel[0]: Resetting IOCatalogue.
Any input is highly appreciated! Thanks in advance.
