Hi all,
So we are currently moving from 2 domains to one, where each had different username.
What I'm looking to do is script the move so it renames the existing user folder to what the new login will be.
So Essentially,
Unbind from old domain, delete the dscl record, (keep mobile user folder)
rebind to new domain, then prompt user for the new username (this will be techs running the migrate)
use the new username to rename the users old folder, then apply the correct permissions to that folder using the new username. then probably a restart im guessing.
Been playing with a script from @stevewood that has some things that will work. But just need the rename piece and the prompt for new user name
# Name: moveDomains.sh
# Date: 28 May 2014 v1.0
# Updated: 18 Jun 2014 v1.1
# Author: Steve Wood (swood@integer.com)
# Purpose: used to move users from one AD domain to a new one, or from OD to AD
# Updates: v1.1 - set GroupID to static
# - v1.1 - including message to users using jamfhelper
# - adding code to check for domain membership
# Prequisites: You'll need a policy in your JSS
# Globals & Logging
LOGPATH='<WHERE YOU STORE LOGS>' # change this line to point to your local logging directory
if [[ ! -d "$LOGPATH" ]]; then
mkdir $LOGPATH
set -xv; exec 1> $LOGPATH/movedomainslog.txt 2>&1 # you can name the log file what you want
version=1.1
oldAD='*****.internal'
currentAD=`dsconfigad -show | grep -i "active directory domain" | awk '{ print $5 }'`
# let the user know what we are doing
banner=`/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType hud -title "Moving Domains" -heading "Moving Domains Header" -description "We are moving your user account to the new authentication domain. When we are completed, and your computer restarts, you will be able to login to your computer with your new domain credentials." -button1 "Proceed" -button2 "Not Now" -defaultButton 1 -cancelButton 2 -timeout 60 -countdown`
if [[ $banner == "2" ]]; then
echo "User canceled the move."
exit 1
# Grab current user name
loggedInUser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'`
##### if you do not have OD deployed you can remove the follwing lines
# unbind from LDAP
# sinc there is no easy way to determine if bound to OD, we will just run against our OD for good measure
dsconfigldap -r *****.internal
# unbind from AD
# check to see if we are bound to our current AD or not. If not we can skip this
if [[ "$currentAD" = "$oldAD" ]]; then
# remove the config for our old AD
# you need a user in your AD that has the rights to remove computers from the domain
dsconfigad -remove $oldAD -user <******> -pass <*******>
# remove the local user from the machine so we get the proper UID assigned in dscl
dscl . delete /Users/$loggedInUser
# bind to new AD
# using a JAMF policy to bind to the new AD
jamf policy -id **** # can also use a custom trigger for the policy
# reset permissions
### some of the code below is courtesy of Ben Toms (@macmule)
# Get the Active Directory Node Name
adNodeName=`dscl /Search read /Groups/Domain Users | awk '/^AppleMetaNodeLocation:/,/^AppleMetaRecordName:/' | head -2 | tail -1 | cut -c 2-`
# Get the Domain Users groups Numeric ID
domainUsersPrimaryGroupID=`dscl /Search read /Groups/Domain Users | grep PrimaryGroupID | awk '{ print $2}'`
accountUniqueID=`dscl "$adNodeName" -read /Users/$loggedInUser 2>/dev/null | grep UniqueID | awk '{ print $2}'`
chown -R $accountUniqueID:$domainUsersPrimaryGroupID /Users/$loggedInUser
# restart the computer when done
# to make sure everything is working properly we will restart
shutdown -r now
