Firefox plugins
  • November 5, 2015
  • 21 views
Can anyone tell me how to deploy firefox plugins with Casper?
  • November 5, 2015
Which particular plugin, it's a slightly different process depending on whether they are internally added ones or something like flash that is added with an external installer.
It also varies depending on whether you are using a user template for the Firefox settings, or some kind of management like either the built in Firefox one or the CCK2 addon management.
  • November 5, 2015
The plugins are chris pedericks stuff
Firebug.
I'm not using management
