I work in a school environment and I'm using configuration profiles to restrict access to most of the settings within system preferences.
I re-image the computers, the policies applied and system preferences look like pic attached (#1) where the students can access the enabled settings and the blocked settings are greyed out, which is the way I want it.
What happens now if that some of the kids where able to get around this and as you can see in pic #2, the greyed out settings are gone from system preferences but if you click on 'view' at the top, all system preferences are enable.
To good part about this is that even though they got access to all the settings, they can't access them since they don't know the admin password. I have looked at the logs is casper and on their Macbook and can't find any evidence of they knowing the admin password
Not sure how they where able to enable all the settings in system preferences, does anyone know how to replicate what happened ? (removing the disable settings from system preferences but able to see them enable in 'view) so I can tackle the problem. I'm assuming they deleted a file(s) somewhere to make it happen.
By the way, they can duplicate system preferences and remove the NSPrefpaneGroups.xml from the contents folder if they are login as admins which isn't the case since the NSPrefpaneGroups.xml file is still there.
Macbooks are running osx 10.9.5
Using casper 9.6
Cheers,
Henry
