Office 365 VPP update not downloading
  • April 29, 2019
  • 6 replies
  • 37 views
Cayde-6
Forum|alt.badge.img+22
Hey all,
So MS Excel & PowerPoint have updated to 16.24 along with the new icons but Outlook, Word, OneNote are still on 16.23. I did see an appdownload stub for those apps but running a recon waited, reboot have not solved the issue
Any ideas?
  • April 29, 2019
Same issue here.
ImAMacGuy
Forum|alt.badge.img+23
  • April 29, 2019
I haven't checked o365 in particular, but with other apps, if the users installed through an alternate source (downloaded/installed manually, or pushed via installer package) then VPP will not update it. It will only update apps that were installed via VPP.
Cayde-6
  • April 29, 2019
Office 365 was pushed via VPP
  • April 29, 2019
Solved the issue the old way. Delete the stub installers, go to the computer record in Jamf > Management tab > Cancel all failed commands. Back to the Mac, sudo Jamf recon in terminal. Re-download begins again.
Ugh.
  • April 29, 2019
The stubs and subsequent download issue should have been fixed in 10.14.4.
Since upgrading, I haven't seen any additional issues.
ThijsX
Forum|alt.badge.img+20
  • Employee
  • April 30, 2019
Hee there,
You can check macadmins.software/mas/ for known issues and workarounds!
If you stumble up on other issues join macadmins on slack and join #microsoft-office or ping pbowden!
