If a software is already installed on a Macbook and the user tries to install it again from Self Service then in this case Self Service gives you an error message "contact your administrator". In logs it shows that DP is already mounted. The question is that a normal practice that we hide the softwares/ applications from the macbook if it is already installed on Macbook.
Self Service error Contact administrator
