Computer and Mobile Search Inventory Broken in 9
  • August 23, 2013
  • 8 replies
  • 34 views
Since the v9 upgrade and the cert authority issue now noticing that the search isn't working for mobile and computer inventories.
Any ideas on how to restore this?
Best answer by mm2270
Can you be more specific on what you're seeing? Are you searching using the wildcard character (*) if you're not entering a full computer or mobile device name?
  • August 23, 2013
  • August 23, 2013
What a pain...
This seems like a step back in time...like before we had Spotlight or Google.
  • August 26, 2013
I noticed that it seems not to do substring searches anymore from the first search box.
Workaround: If you click Search with nothing, you get the full list. Then type in a substring search in the Filter Results box and get a result.
But that's a bit of a unnecessary two-step.
  • August 26, 2013
But it does do substring searches (the gist of this very post) by adding asterisks around the string. Either after or before or both, depending on what you're looking for. Its a big change from all previous versions of the JSS as far back as I can recall. But I think the reason behind it is so you can now do things like include/exclude within the basic search, which wasn't really possible before.
That said, the filtering field is a welcome addition. However, I wish the Export and Action buttons didn't vanish as soon as you filter a search. Why not allow us to do something with filtered results other than just look at them? :/ That seems to limit the filters usefulness to me.
  • August 27, 2013
I was hit by this as well.
Can you elaborate how a substring search would work? syntax examples...
  • September 19, 2013
We are having the same issue. This should work just like previous versions did. I would be able to type 15 into the search box and any computer name that had 15 in it should pop up in the list.
  • October 23, 2013
Here is what I'm seeing when performing searches. Let's say the computer I'm looking for is "Forrest-Gump-1234."
Search for "Forrest"...returns nothing. (In version 8, this would return all computers containing "Forrest.")
Search for "Forrest-Gump-1234"...returns "Forrest-Gump-1234."
Search for "Forrest*"...returns "Forrest-Gump-1234" (and I assume anything else starting with "Forrest.")
...I'm not a smart man...but I know what search is.
(Edit: I'm on 9.2)
  • October 23, 2013
We've had this issue since 9 as well. Very annoying - especially after everything that was gained in 9.x.
