Download Configuration Profiles for manual install in OS X
  • July 19, 2012
  • 20 replies
  • 112 views
Anyone know how to do this?
I am creating Configuration Profiles for 10.7 but need to download them and deploy using Profiles -I -F
Anyone else doing this? If so how?
Best answer by matt4836
Thanks Nessts, the command I was looking for was provided by Brad Brecker from JAMF:
https://yourjssurl.com/exportOSXConfigurationProfile.html
This will allow me to download my Configuration Profiles I created in the JSS.
Thanks all!
  • July 19, 2012
you can put them in /private/var/db/ConfigurationProfiles/Setup/ and in theory at first boot OS X will install them for you.
I have found it to be less than completely successful everytime, so i have written a job to check a folder of my own location and install them when I choose during the firstboot process, profiles -I -F /path/to/profile
, works quite well.
  • July 19, 2012
Thanks all!
  • July 19, 2012
Timely! Thanks for posting the question and solution. Is there a corresponding page for mobile device profiles?
  • July 19, 2012
looks like the one for mobile devices profiles is located at
https://yourjssurl.com/exportConfigurationProfile.html
  • July 19, 2012
I've got a (potentially) dumb question to add to this...
I've searched around a bit, but have not found an answer. How does one actually CREATE custom configuration profiles, let alone import them into the JSS?
I imagine that there is all kinds of things that can be done with them, but I have not had much luck.
  • July 19, 2012
Awesome thanks!
Forum|alt.badge.img+19
  • July 20, 2012
this only shows my uploaded profiles. But not the ones I have created within JSS.
  • July 20, 2012
Not the case for me. I just created 2 new Config Profiles on our test 8.5.2 JSS, one OS X and one MDM. Hitting those respective pages shows them available for download. I never uploaded them. Not sure why they wouldn't be showing up for you.
  • July 24, 2012
OK this function is not working in jss v8.43. I think only applies to jss v8.5+
  • July 24, 2012
I'm sorry Cem, but there must be something wrong. We have an 8.4 JSS (production) and I just created 2 Config Profiles, one OS X and one MDM and the above commands allow me to see them and download them just fine. Perhaps its broken in 8.43 specifically, but worked in 8.4 and then again in 8.52? Seems unlikely but I guess its possible.
The only other thing I can think of is our JSS doesn't need the port at the end of the URL, it just ends with .com, so when I enter the address, its like https://JSSurl.com/exportOSXConfigurationProfile.html. Are you entering it without the port in the address, or with it? I think it needs to be the former.
  • July 25, 2012
@mm2270
OK I stand corrected!
Following works in our environment with 8.43 and 8.52
https://JSSurl.com:8443/exportOSXConfigurationProfile.html
http://JSSurl.com:9006/exportOSXConfigurationProfile.html
It doesn't work without the port though.
  • August 2, 2012
Thanks for this info, Matt4836! Saved me a bunch of headaches. I owe you a beer at the JNUC! :)
  • August 2, 2012
Andy I am in Indy right now. Can I cash that in? (I prefer Cherry Coke Zero).
  • August 10, 2012
I tried it, it did not work for me(Page not found).
What I found is
exportOSXConfigurationProfile.html - is case sensitive.
https://jss.company.com:8443/exportOSXConfigurationProfile.html
  • September 20, 2012
@dzmudzki - try without the port :8443 or :9006, see how it goes;
https://jss.company.com/exportOSXConfigurationProfile.html
or
http://jss.company.com/exportOSXConfigurationProfile.html
  • September 20, 2013
This has been very useful, except when I try manually applying the profile I have created I get this back from Profiles...The profile is a user profile but contains a "System Policy Control" payload which is only valid in device profiles. So I am trying to figure out how I separate the pieces of the profile and how I make a device profile out of Casper?
  • November 9, 2013
Is this no longer possible with JSS 9?
Edit: I guess this functionality has been replaced with the "Download" button in the settings of the configuration profile.
  • August 16, 2016
It only installs and not download.. when i click the "Downloads" button
  • August 16, 2016
@JustDeWon I think that's just way mobileconfig files behave when you download them. You don't have to actually install, just cancel when it prompts you. It should still download tho.
  • August 16, 2016
@denmoff ..Ahh.. I see, I should have checked there.. Awesome Thanks
