Hi...
our school bought an app 3 licences... and we are trying to push those apps from the mac app store, bought from the VPP, to computers with 10.11.3.
The apps gets installed, at least partially... the app is 50Mb... and only 377kb gets installed from the app...
tried 2-3 times... same thing...
Similar issue here although your getting something downloaded. Issue for us is with MacBook Air systems. App Store apps will not download through self service or allow me to push. Self service will have an error to contact the administrator and attempting to just install will not work. The jss in history shows the attempt with an error contacting the Apple push notification servers and then just sits there. We have open case regarding issue. On an iMac this all works as it should so something to do with MBA systems.
