Remove all apps with no scope? - Apps duplicated
  • June 15, 2018
  • 4 replies
  • 21 views
Nick_Gooch
We have it enabled so mobile apps auto populate after purchasing. At some point the server reimported all the mobile device apps, not once but three times. Now I have 1,100 apps in the catalog. Anyone have a script to pull all apps with no scope and then delete them from the server?
  • June 15, 2018
I encountered this same issue about a month or two ago. I ended up deleting them all manually, one by one.
  • September 14, 2018
We had something similar happen. The minimum number of duplicates I've seen is 4. The maximum so far is 18.
How is your Powershell? I can give you a portion of a script I run to do yearly mobile app audits. You will probably have to tweak/modify it to work for you.
  • March 2, 2020
Same issue but over 150 apps to delete manually. What a pain!
