Mac App Store checkboxes greyed out
  • August 12, 2019
  • 4 replies
  • 37 views
Schedule Jamf Pro to automatically check iTunes for app updates.
Automatically Force App Updates.
I know I will feel stupid when someone answers this.
Why are the options above greyed out and not editable? For some apps I do not want the app to force the update. I want to be able to test the app and deploy a week or 2 after the release.
Thanks.
  • August 12, 2019
If I were a betting man, I'd say both checkboxes are enabled under Settings > Device Management > App Maintenance. That's a global setting, so forcing it on at a global level will check and enforce those boxes for all other apps.
  • August 12, 2019
No checked...
  • August 12, 2019
Got it. Its under Computer Management>App Updates. Duh. I feel dumb now.
Thank you.
  • August 12, 2019
Ah, didn't look hard enough that Excel was the app in question, so yeah that'd be App Updates under Computers instead of Mobile Devices :) Glad you found it.
