Firefox Developer Edition Install Script
  • October 12, 2018
  • 0 replies
  • 21 views
Hi all,
Theres some nice scripts I've found here that automatically update/install Firefox and Firefox ESR. We had a requirement to do the same for Firefox Developer Edition. I had some problems getting the full version of FF Developer (It wasn't in info.plist) and ended up having to log a bug with Mozilla. A developer then showed me where to get the full version.
Anyway I thought I'd post this and share with the community :)
#James Durler
#Date: 3/10/2018
#Script to automatically read the latest version of Firefox Developer , check the version on the machine and install the latest if required
#Based on Joe Farage and Deej's work to automatically update Firefox and Firefox ESR
dmgfile="FF.dmg"
logfile="/Library/Logs/FirefoxDevInstallScript.log"
lang="en-GB"
#Read latest developer edition version
latestDevVersion=`curl -s 'https://product-details.mozilla.org/1.0/firefox_versions.json' |     /usr/bin/python -c "import sys, json; print json.load(sys.stdin)['FIREFOX_DEVEDITION']"`
echo "`date`: Latest Developer Version is: $latestDevVersion" >> ${logfile}
function installFirefoxDev {
        url="https://download-installer.cdn.mozilla.net/pub/devedition/releases/${latestDevVersion}/mac/en-GB/Firefox%20${latestDevVersion}.dmg"
        echo "`date`: Download URL: $url" >> ${logfile}
        echo "`date`: Downloading newer version." >> ${logfile}
        /usr/bin/curl -s -o /tmp/${dmgfile} ${url}
        /bin/echo "`date`: Mounting installer disk image." >> ${logfile}
        /usr/bin/hdiutil attach /tmp/${dmgfile} -nobrowse -quiet
        /bin/echo "`date`: Checking if Firefox Developer is currently running and will kill if it is" >> ${logfile}
        firefoxid=`pgrep firefox`
        if [ -z "$firefoxid" ]
        then
            /bin/echo "`date`: Firefox is not running, proceeding with install" >> ${logfile}
            /bin/echo "`date`: Firefix is running, killing process" >> ${logfile}
            kill -9 $firefoxid
        /bin/echo "`date`: Installing..." >> ${logfile}
        ditto -rsrc "/Volumes/Firefox Developer Edition/Firefox Developer Edition.app" "/Applications/Firefox Developer Edition.app"
        chown -R root:wheel "/Applications/Firefox Developer Edition.app"
        /bin/sleep 5
        /bin/echo "`date`: Unmounting installer disk image." >> ${logfile}
        /usr/bin/hdiutil detach $(/bin/df | /usr/bin/grep Firefox | awk '{print $1}') -quiet
        /bin/sleep 5
        /bin/echo "`date`: Deleting disk image." >> ${logfile}
        /bin/rm /tmp/${dmgfile}
#Check if firefox developer is installed and if it is read the version installed locally
if [ -d /Applications/Firefox Developer Edition.app ]
then
    echo "`date`: Firefox Developer Edition is installed" >> ${logfile}
    #Get the version installed - remove speech marks and any commas
    currentinstalledver=`unzip -p /Applications/Firefox Developer Edition.app/Contents/Resources/omni.ja modules/AppConstants.jsm 2>/dev/null | grep MOZ_APP_VERSION_DISPLAY | awk '{print $2}' | tr -d " | sed 's/,/ /g'`
    #If the version installed is equal to the latest then exit
    if [ ${currentinstalledver} = ${latestDevVersion} ]
    then
        echo "`date`: Current Version: $currentinstalledver" >> ${logfile}
        echo "`date`: Firefox Developer Edition is current, exiting" >> ${logfile}
    #Otherwise update
        /bin/echo "`date`: Latest version is not installed, installing latest version of Firefox Developer Edition" >> ${logfile}
        installFirefoxDev
#Otherwise install Firefox Developer Edition
    echo "`date`: Firefox Developer Edition is not installed, installing now" >> ${logfile}
    installFirefoxDev
