Backblaze: replace editable.xml
  • June 23, 2020
  • 0 replies
  • 12 views
I wanted to deploy BackBlaze backup Software using Jamf and I did it without problem.
I would like now to set new exclusions.
I can do it locally by editing bzexcluderules_editable.xml inside /Library/Backblaze.bzpkg/bzdata and it works.
There is a way to push the bzexcluderules_editable.xml using JAMF considering that it is embedded into a .bzpkg file?
Thank you in advance.
