Reset Safari Data - iOS
  • October 7, 2021
  • 28 views
Hi All,
I have setup a Jamf Setup and Reset configuration, and this works with removing the Microsoft login data from Safari, but...........the page is still open, and another user can get a "view" of a current page eg. portal.office.com, as soon as you try get to another page, it brings up the authentication page which it should.
Is there anyway to close down Safari and essentially do a soft reset of Safari, and not just the Microsoft credentials.
I know this can be done via settings, even if I have to use another app if possible.
Regards
Simon
1 reply
  • March 29, 2023
Hi Simon, did you ever find a work around to this?
