Your apple id can't be used in this store this apple id is associated with apple school manager
  • November 16, 2021
  • 21 views
Your apple id can't be used in this store this apple id is associated with apple school manager.  That's the message I get in Jamf Pro despite following all of the steps I can think of.
For some reason can't get eBooks installed and instead getting that message because it's a Managed Apple ID.
1 reply
  • November 17, 2021
We use Managed Apple IDs and I have pushed out a few books. Since books are assigned to the user rather than the device you need to make sure that the Apple IDs have accepted the VPP invitation. Under the VPP option in Settings we have the Automatically register with volume purchasing if users have Managed Apple IDs option checked. Then we had to create an invitation in the Users section for that VPP option. I wish I could pull screenshots but since we are on the cloud it times out trying to get to these pages anymore.
Once that was done I could purchase the books from Apple School Manager and have the licenses available in the Volume Assignments section under Users. There you can scope it to your groups.
