JAMF Pro scoping mobile apps to AAD groups
  • May 10, 2022
  • 0 replies
  • 7 views
We recently completed a cutover from on-prem LDAP user/group auth to AAD. Previously we had little to no reliance on LDAP groups for smart device groups or app deployment, however as we scale up we're wanting to leverage AAD for group based app deployment. The issue is when I create a "standard" group that matches the AAD group, it doesn't appear as a selectable group in the scope/target settings for the apps. I found a thread online that suggested setting the scope target to all devices, and use the LDAP limitations fields to specify the group name. I haven't tested this yet, but was wondering if anyone else had performed this migration/transition and if that's the recommended solution for scoping to AAD user groups or knows the correct approach.
