Screen Recording Enabled/Not Enabled by App
  • September 12, 2024
  • 19 views
mwestaph
Since Sequoia will be prompting users to review their screen recording settings monthly, I was wondering if it was possible to create a Smart Group that displays which apps in the Screen & System Audio Recording are either enabled or not enabled. Ideally, I'd be able to query by app name (Teams, Chrome, Zoom, etc).
My goal is to regularly prompt users to turn this setting on for the app(s) it is not enabled for.
Thanks,
Michael
1 reply
  • September 13, 2024
Sorry, but no. You would need an EA to do the checking, and Apple had SIP block access to the relevant database a few major OS version ago.
