I just setup a AWS Cloud Distribution Point with the thought that I would use it as a failover for our JDS in the event that we have a network or power outage (JSS is hosted externally) however it appears that there is no option to do this.
The only way I see to be able to have the cloud distribution point used as a non-primary/backup solution is to manually set the Cloud Distribution Point as the primary distribution point in the event of a failure of the JDS. This method isn't great either though because I don't want to store OS images on my AWS bucket and as a result if the JDS came back online and sync'd to the AWS bucket, I imagine it would blow out the images I have on the JDS.
Is the above thought process valid or am I missing something?
I looked into network segments but came to the issue that we are not a multi-site company but rather a company with one home office and ~100 field users spread across the United States. The only way I see having the AWS bucket in the mix with network segments is to make it the primary distribution point and to then set my JDS to be the primary for the home office network segment. I don't feel this is a great option though as it would significantly and unnecessarily increase our AWS costs due to all of the field users hitting AWS as the primary rather than the JDS.
TL:DR: What's the best way to setup a Cloud Distribution Point as a failover for a JDS in a single JDS environment with geographically dispersed users.
