Does anyone here manage Home Sync settings with configuration profiles? I can't for the life of me get clients (10.7.4) to obey the setting to SyncBackgroudSetAtLogout when managed by config profiles. If I use a user-lever profile the mobility settings are ignored at login and all folders begin syncing (as opposed to just Desktop and Documents) and if I use a custom home sync payload in a system-level profile everything works except syncing at logout. It just logs out without syncing. As I said before our clients are running 10.7.4 and I just updated our JSS to 8.64 from 8.62. This is a major inconvenience for our Teachers because in some usage scenarios, they need to get second grade students to manually sync before logging out.
Possibly OT - Home Sync at logout
