Hi all,
Don't know if any of you experience this.
Our fleet of Macbooks are on Sierra, High Sierra and Mojave.
On Mojave, it doesn't matter the year model of the Macbook, just seems to run really slowly when connecting with JAMF Pro.
For example, when I type in sudo jamf policy -event xyz, on Mojave, it would take 2-3 times as long to finish the policy than say on High Sierra.
When starting Self Service, on a Mojave Macbook, the app will take a few bounces, then it can connect with JAMF Pro and open up properly. On Sierra or High Sierra, it's fairly instantaneous.
Because it works great on Sierra and High Sierra, I don't believe JAMF Pro server performance is the issue. Rather I am thinking is Mojave blocking something?
We are currently on JAMF Pro 10.8. Would upgrading to later versions of JAMF Pro help?
