Azure AD login window does not pop up properly after restart
  • December 9, 2022
  • 14 views
Is there any known issue or someone faced the issue?
Forum|alt.badge.img+20
  • December 9, 2022
That is usually a case that the configuration profile has been removed for some reason. Take a look at your Management History for the computer and see if the profile was removed. Then double checking your scoping to make sure the computer didn't fall out of scope.
MannyKrishna
  • December 10, 2022
In our case sometime it occurred and if users do refresh at login then it is showing up azure login
  • December 10, 2022
Thanks guys, I'll check with your feedbacks and update you here
