Trying to delete User accounts with JAMF Schools Script
  • June 5, 2024
  • 0 replies
  • 19 views
Trying to delete User accounts with JAMF Schools Script.
I had it not error before and it seemed to delete but the account would still be on the login screen. ~
users=("Class1")
# Delete users and their home directories
for user in "${users[@]}"; do
# Check if the user exists
if dscl . -read /Users/$user &>/dev/null; then
# Delete the user account
sudo dscl . -delete /Users/$user
# Remove the user's home directory
sudo rm -rf /Users/$user
echo "Deleted User -> $user and their home directory"
echo "User $user does not exist"
done
Im returning
1:233: execution error: /Library/Application Support/ZuluDesk Scripting/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f.command: line 2:
: command not found
/Library/Application Support/ZuluDesk Scripting/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f.command: line 4:
: command not found
/Library/Application Support/ZuluDesk Scripting/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f.command: line 6: syntax error near unexpected token `do
/Library/Application Support/ZuluDesk Scripting/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f/com.zuludesk.scripting.08af6178-237d-11ef-8da8-024f99ac106f.command: line 6: `for user in "${users[@]}"; do
' (2
