RunSAVLiveUpdate
  • May 10, 2010
  • 6 replies
  • 37 views
ImAMacGuy
Forum|alt.badge.img+23
We are trying to get the Symantec live update script running from the
resource kit. When we run the script through 'unix commands' through ARD it
runs normally. But when we push the script through Casper it bombs out
with...
Preparing Management... Executing Policy 2010-05-10 at 12:01 PM | jwojda | 1 Computer... Mounting afp://srshofmacdply01.kih.kmart.com/CasperShare to
/Volumes/CasperShare 1... Running Script zzrunSAVLiveUpdate.sh... Script Exit Code:126 Script Result: sh: /private/tmp/zzrunSAVLiveUpdate.sh: /bin/sh if: bad interpreter: No such file or directory Unmounting file server... Enforcing Management Framework... The Management Framework will be enforced as soon as all Policies are done
executing.
We set the script to Executable, but it won't work on the test boxes. We
also can't run it locally through sudo either.
Script as follows...
if [ -f "/Applications/Symantec
Solutions/LiveUpdate.app/Contents/MacOS/LiveUpdate" ]; then echo "Running LiveUpdate..." /Applications/Symantec
Solutions/LiveUpdate.app/Contents/MacOS/LiveUpdate -update LUal
-liveupdatequiet YES -liveupdateautoquit YES
else echo "Error: Symantec LiveUpdate was not found on this machine." exit 1
Fi
  • May 10, 2010
An error 126 indicates permissions problems. But, I see you mounting locally as "/Volumes/CasperShare 1" Do you have something else already mounting the CasperShare as a different user? I run into this when I try and run something locally on my machine and (stupidly) have a volume on the same server mounted as a user that doesn't have access into the CasperShare.
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • May 10, 2010
On 5/10/10 12:13 PM, "Wojda, John" <john.wojda at searshc.com> wrote: #!/bin/sh if [ -f "/Applications/Symantec Solutions/LiveUpdate.app/Contents/MacOS/LiveUpdate" ]; then echo "Running LiveUpdate..." /Applications/Symantec Solutions/LiveUpdate.app/Contents/MacOS/LiveUpdate -update LUal -liveupdatequiet YES -liveupdateautoquit YES else echo "Error: Symantec LiveUpdate was not found on this machine." exit 1 Fi
Throwing this out as an alternative:
I just take this part:
and put it into a scheduled task in the JSS, applying it to all my
workstations. It's simpler and works fine.
This avoids maintaining a script, avoids permission issues, etc.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
golbiga
Forum|alt.badge.img+21
  • Employee
  • May 11, 2010
Is there any way to suppress the icon from launching in the dock when using this scheduled task?
Thanks Allen
talkingmoose
  • Community Manager
  • May 11, 2010
Hi Patrick!
On 5/11/10 7:36 AM, "Bachuwa, Patrick" <Patrick.Bachuwa at searshc.com> wrote:
Whether you're calling the SAV command using a shell script or as a task in
Casper, the time to update will be the same. It's the same command either
way, just invoked differently.
Does that give you what you're needing to know?
William Smith
Technical Analyst
(651) 632-1492
  • May 11, 2010
I ran it and it doesn't seem to run the update, I waited for an hour and ran it manually so I know the script didn't run it.
Patrick Bachuwa
Client Technical Services
Sears Holdings Corporation
Michigan Campus
3000 W. 14 Mile Road
Royal Oak, MIĀ  48073-1717
Phone: 248 637-0350
talkingmoose
  • Community Manager
  • May 11, 2010
These are my settings under Management tab --> Scheduled Tasks in the JSS:
On 5/11/10 9:51 AM, "Bachuwa, Patrick" <Patrick.Bachuwa at searshc.com> wrote:
Display Name: Daily SAV Update - Desktop Run as User: root
Run Command: '/Applications/Symantec
Solutions/LiveUpdate.app/Contents/MacOS/LiveUpdate' -update LUal
Minute: On the hour Hour: 1 AM Day: Every Day Month: Every Month Randomize Execution By: 1 Hour
Scope: All Desktops
Once you set the task, you'll need to make sure your machines are receiving
the new task. They should receive it the next time they login/logout/startup
when "Enforce Management Framework" is execute, however, you can run the
JAMF command line on each machine to update them immediately:
sudo jamf checkForTasks
Hope this helps!
William Smith
Technical Analyst
(651) 632-1492
