There's another way that's better. Download the installer from the MAS using this process:
https://derflounder.wordpress.com/2013/08/22/downloading-apples-server-app-installer-package/
Then have a script in the policy that runs AFTER:
# DevToolsSecurity tool to change the authorization policies, such that a user who is a
# member of either the admin group or the _developer group does not need to enter an additional
# password to use the Apple-code-signed debugger or performance analysis tools.
/usr/sbin/DevToolsSecurity -enable
# Accept Xcode License
/Applications/Xcode.app/Contents/Developer/usr/bin/xcodebuild -license accept
# Install Additional Components
/usr/sbin/installer -pkg /Applications/Xcode.app/Contents/Resources/Packages/MobileDevice.pkg -target /
/usr/sbin/installer -pkg /Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg -target /
Thank you for the info I will give this a shot.
Quicknote: make sure your internal SUS is updated. It will save some time pulling down the command line tools
@bpavlov we follow a similar process for installing additional components but it doesn't seem to run correctly with El Capitan. have you encountered this yet?
We haven't tried with El Capitan yet. When you say it doesn't run with El Capt, what errors are you getting?
Basically, additional components do not install via postinstall script. You can run the command via terminal with no issues. But if you run it via a postinstall script, console throws back a ton of errors, and when you launch Xcode for the first time you are still prompted with installing additional components. Looks like SIP is wreaking havoc.
After reading this post I figured I'd test deploying xcode 7.1.1 to my 10.11.2 tester Mac. I'm using the same .dmg and post-install script that I use on our Yosemite Machines. I watched as it copied the 9GB .app to /Applications and then it ran the script (very similar to @bpavlov's script) and then Self Service said it failed. I checked the log and it also says it failed, but I can't find any indication of actual failure.:
Script result: Dec 10 13:13:31 installer[3662] : Package Authoring Warning: The deleteObsoleteLanguages flag is ignored. No languages will be removed.
Dec 10 13:13:32 installer[3662] : Referenced component packages (1) trustLevel=501
Dec 10 13:13:32 installer[3662] : -[IFPKGDerivedDocument sortedPackageLocations]: result = (
"file://localhost"
Dec 10 13:13:32 installer[3662] : -[IFDInstallController(Private) _buildInstallPlanReturningError:]: location = file://localhost
Dec 10 13:13:32 installer[3662] : -[IFDInstallController(Private) _buildInstallPlanReturningError:]: file://localhost/Applications/Xcode.app/Contents/Resources/Packages/MobileDevice.pkg
Dec 10 13:13:32 installer[3662] : Set authorization level to root for session
Dec 10 13:13:32 installer[3662] : Administrator authorization granted.
Dec 10 13:13:32 installer[3662] : Will use PK session
Dec 10 13:13:32 installer[3662] : Using authorization level of root for IFPKInstallElement
Dec 10 13:13:32 installer[3662] : Starting installation:
Dec 10 13:13:32 installer[3662] : Configuring volume "Macintosh HD"
Dec 10 13:13:32 installer[3662] : Preparing disk for local booted install.
Dec 10 13:13:32 installer[3662] : Free space on "Macintosh HD": 212.67 GB (212672229376 bytes).
Dec 10 13:13:32 installer[3662] : Create temporary directory "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T//Install.3662qbiAz1"
Dec 10 13:13:32 installer[3662] : IFPKInstallElement (1 packages)
Dec 10 13:13:32 installer[3662] : PackageKit: Enqueuing install with framework-specified quality of service (utility)
installer: Package name is MobileDevice
installer: Upgrading at base path /
installer: Preparing for installation….....
installer: Preparing the disk….....
installer: Preparing MobileDevice….....
installer: Waiting for other installations to complete….....
installer: Configuring the installation….....
installer:
installer: Optimizing system for installed software….....
installer: Running package scripts….....
installer: Cleaning up….....
installer: Validating packages….....
#Dec 10 13:14:03 installer[3662] : Removing temporary directory "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T//Install.3662qbiAz1"
Dec 10 13:14:03 installer[3662] : Finalize disk "Macintosh HD"
Dec 10 13:14:03 installer[3662] : Notifying system of updated components
Dec 10 13:14:03 installer[3662] : **** Summary Information ****
Dec 10 13:14:03 installer[3662] : Operation Elapsed time
Dec 10 13:14:03 installer[3662] : -----------------------------
Dec 10 13:14:03 installer[3662] : zero 0.00 seconds
Dec 10 13:14:03 installer[3662] : disk 0.09 seconds
Dec 10 13:14:03 installer[3662] : install 31.18 seconds
Dec 10 13:14:03 installer[3662] : -total- 31.27 seconds
installer:
installer: Finishing the Installation….....
installer:
installer: The software was successfully installed......
installer: The upgrade was successful.
Dec 10 13:14:03 installer[3723] : Package Authoring Warning: The deleteObsoleteLanguages flag is ignored. No languages will be removed.
Dec 10 13:14:03 installer[3723] : Referenced component packages (1) trustLevel=501
Dec 10 13:14:03 installer[3723] : -[IFPKGDerivedDocument sortedPackageLocations]: result = (
"file://localhost"
Dec 10 13:14:03 installer[3723] : -[IFDInstallController(Private) _buildInstallPlanReturningError:]: location = file://localhost
Dec 10 13:14:03 installer[3723] : -[IFDInstallController(Private) _buildInstallPlanReturningError:]: file://localhost/Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg
Dec 10 13:14:03 installer[3723] : Set authorization level to root for session
Dec 10 13:14:03 installer[3723] : Administrator authorization granted.
Dec 10 13:14:03 installer[3723] : Will use PK session
Dec 10 13:14:03 installer[3723] : Using authorization level of root for IFPKInstallElement
Dec 10 13:14:03 installer[3723] : Starting installation:
Dec 10 13:14:03 installer[3723] : Configuring volume "Macintosh HD"
Dec 10 13:14:03 installer[3723] : Preparing disk for local booted install.
Dec 10 13:14:03 installer[3723] : Free space on "Macintosh HD": 211.79 GB (211785162752 bytes).
Dec 10 13:14:03 installer[3723] : Create temporary directory "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T//Install.3723LQqScE"
Dec 10 13:14:03 installer[3723] : IFPKInstallElement (1 packages)
Dec 10 13:14:03 installer[3723] : PackageKit: Enqueuing install with framework-specified quality of service (utility)
installer: Package name is MobileDeviceDevelopment
installer: Installing at base path /
installer: Preparing MobileDeviceDevelopment….....
installer:
installer: Moving items into place….....
installer: Registering updated components….....
#Dec 10 13:14:31 installer[3723] : Removing temporary directory "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T//Install.3723LQqScE"
Dec 10 13:14:31 installer[3723] : Finalize disk "Macintosh HD"
Dec 10 13:14:31 installer[3723] : Notifying system of updated components
Dec 10 13:14:31 installer[3723] : **** Summary Information ****
Dec 10 13:14:31 installer[3723] : Operation Elapsed time
Dec 10 13:14:31 installer[3723] : -----------------------------
Dec 10 13:14:31 installer[3723] : zero 0.00 seconds
Dec 10 13:14:31 installer[3723] : disk 0.03 seconds
Dec 10 13:14:31 installer[3723] : install 28.11 seconds
Dec 10 13:14:31 installer[3723] : -total- 28.14 seconds
installer:
installer:
installer: The install was successful
I launched XCode and was quickly brought to the "Welcome to XCode splash screen" No prompts to install components appeared. All actual proof says the install was successful, but for some reason JSS 9.81 says it failed. Again, this is the exact same Policy that I install on Yosemite Macs and none of them show up in JSS as Failed. I'm getting real tired of "failures" that aren't actual failures.
Here's the script I'm using
# exclude xcode from gatekeeper verification, which can take hours.
if [[ -e "/Applications/Xcode.app" ]]; then xattr -dr com.apple.quarantine /Applications/Xcode.app
# Accept EULA so there is no prompt
if [[ -e "/Applications/Xcode.app/Contents/Developer/usr/bin/xcodebuild" ]]; then
# Install Mobile Device Package so there is no prompt
if [[ -e "/Applications/Xcode.app/Contents/Resources/Packages/MobileDevice.pkg" ]]; then
/usr/sbin/installer -dumplog -verbose -pkg "/Applications/Xcode.app/Contents/Resources/Packages/MobileDevice.pkg" -target /
if [[ -e "/Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg" ]]; then
/usr/sbin/installer -dumplog -verbose -pkg "/Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg" -target /
In the output, there's a section that says _buildInstallPlanReturningError
. As it contains the word Error, Casper reports a failure.
To fix that, change the installer
commands from /usr/sbin/installer -dumplog -verbose -pkg
to /usr/sbin/installer -pkg
. That should take the Error word out of the logs.
UGH. The error recognition in JSS needs room for improvement.
I just looked at the logs from my Yosemite successes and they don't have that
part. I guess that's why they recorded as Completed.
Hey Guys;
Also just started working on 10.11.2 test machine. I was able to get xcode 7.0 installed with a variation of that script using Munki with no problems going to step from 7.1 to 7.2 will update when done
LSinNY
So what we do it slightly different than most. I repackage Xcode using the developer.apple.com version and add a postinstall script where the additional components install. This has worked flawlessly until 10.11. For whatever reason installing additional components via the postinstall results in failure, installing via a separate script results in success.
So I think I understand where some of you are running into problems. If you take an Apple-signed pkg that installs in SIP areas and try to call that via a postinstall script, the packages will fail to install successfully. This is because you are using an non-Apple signed package to essentially install in SIP areas which only Apple can do. Yes, you are ultimately calling an Apple pkg in the postinstall script, but that doesn't matter.
This was talked about a month or two ago on another thread where I made a similar discovery. Basically, what you want to do is call the Apple-signed pkg via a regular script (most likely an AFTER) and it should install successfully.
@bpavlov Can you please specify what you mean with the "AFTER" script? how do you execute that within the Xcode install?
Hey Guys;
I have installed Xcode on 10.11.1 (that was updated to 10.11.2 during imaging) from 7.0 to 7.2 with no issues using Munki with a postinstall script that behaves the way @bpavlov has suggested.
postinstall script -not sure where i got it, but I am not the original author:
## postinstall
# Installing the Xcode command line tools on 10.7.x or higher
osx_vers=$(sw_vers -productVersion | awk -F "." '{print $2}')
cmd_line_tools_temp_file="/tmp/.com.apple.dt.CommandLineTools.installondemand.in-progress"
# Installing the latest Xcode command line tools on 10.9.x or higher
if [[ "$osx_vers" -ge 9 ]]; then
# Create the placeholder file which is checked by the softwareupdate tool
# before allowing the installation of the Xcode command line tools.
touch "$cmd_line_tools_temp_file"
# Find the last listed update in the Software Update feed with "Command Line Tools" in the name
cmd_line_tools=$(softwareupdate -l | awk '/* Command Line Tools/ { $1=$1;print }' | tail -1 | sed 's/^[[ ]]*//;s/[[ ]]*$//;s/*//' | cut -c 2-)
#Install the command line tools
softwareupdate -i "$cmd_line_tools" -v
# Remove the temp file
if [[ -f "$cmd_line_tools_temp_file" ]]; then
rm "$cmd_line_tools_temp_file"
sleep 5
sudo DevToolsSecurity -enable
/usr/sbin/dseditgroup -o edit -a everyone -t group _developer
exit 0 ## Success
exit 1 ## Failure
hth
Larry
@m.entholzner In your Casper policy add a script and make it an AFTER script so that it runs after installing Xcode. In my Casper policy, I have the Xcode pkg from the MAS, and the Xcode CLI Tools from the Dev site, and then an AFTER script which you've already seen posted in this thread.
Noticed 7.2 was released on Dec 8, assuming the above works with that version, downloaded from developer.apple.com. Nice scripts, especially liking the line to add all users to _developer group.
@bpavlov Thank you, that worked! I think it's time for christmas vacation... -.-
It seems that Xcode 7.2.1 doesn't work anymore with this solution.
Interesting is, when you install Xcode 7.2.1 on a clean machine and execute the postinstall, Xcode doesn't work. Installing Xcode 7.2 on the same machine (= downgrade), Xcode will start without any prompts.
It also seems that Xcode beta 7.3 works with the postinstall. Strange thing...
Anyone else seeing this behavior?
I pushed it out yesterday and it's working fine. When you say Xcode doesn't work anymore, what do you mean exactly?
The deployment process isn't working for me. Xcode installs fine, the postinstall script is executed without issues. The packages seem to install fine, but Xcode prompts for that package installs after first launch.
I've attached the script I'm using for postinstall. It is based on the script posted earlier in this thread.
# XcodePostinstall.sh
# Version 1.2
# Created: 14.12.2015
# Modified: 18.01.2016
# Description
# This script will run some postinstall actions after Xcode installation.
# Variables
SCRIPTNAME="XcodePostinstall.sh"
INFODIR="/Library/Management/"
INFOFILE="/Library/Management/informations.plist"
LOGFILE="/Library/Management/$(echo ${SCRIPTNAME} | cut -d . -f1).log"
if [ -d /Applications/Xcode.app ]
then
XCODEVERSION=$(defaults read /Applications/Xcode.app/Contents/version.plist CFBundleShortVersionString)
XCODEBUILD=$(defaults read /Applications/Xcode.app/Contents/version.plist ProductBuildVersion)
if [ -d /Applications/Xcode-[bB]eta.app ]
then
XCODEBETAVERSION=$(defaults read /Applications/Xcode-[bB]eta.app/Contents/version.plist CFBundleShortVersionString)
XCODEBETABUILD=$(defaults read /Applications/Xcode-[bB]eta.app/Contents/version.plist ProductBuildVersion)
# Functions
# Script
# Check if the Infodirectory exists
if [ ! -d ${INFODIR} ]
then
mkdir -p ${INFODIR}
chown -R root:admin ${INFODIR}
chmod -R 755 ${INFODIR}
printf "==================================================
" | tee -a ${LOGFILE}
printf "$(date "+%Y-%m-%d %H:%M:%S") ${SCRIPTNAME} running...
printf "Enabling DevTools Security...
DevToolsSecurity -enable 2>&1 | tee -a ${LOGFILE}
printf "Adding everyone to _developer group...
dseditgroup -o edit -a everyone -t group _developer 2>&1 | tee -a ${LOGFILE}
then
printf "Accepting GM license agreement...
defaults write /Library/Preferences/com.apple.dt.Xcode.plist IDEXcodeVersionForAgreedToGMLicense -string ${XCODEVERSION} 2>&1 | tee -a ${LOGFILE}
defaults write /Library/Preferences/com.apple.dt.Xcode.plist IDELastGMLicenseAgreedTo -string ${XCODEBUILD} 2>&1 | tee -a ${LOGFILE}
printf "Installing GM Mobile Device development packages...
installer -pkg /Applications/Xcode.app/Contents/Resources/Packages/MobileDevice.pkg -target / 2>&1 | tee -a ${LOGFILE}
installer -pkg /Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg -target / 2>&1 | tee -a ${LOGFILE}
then
printf "Accepting Beta license agreement...
defaults write /Library/Preferences/com.apple.dt.Xcode.plist IDEXcodeVersionForAgreedToBetaLicense -string ${XCODEBETAVERSION} 2>&1 | tee -a ${LOGFILE}
defaults write /Library/Preferences/com.apple.dt.Xcode.plist IDELastBetaLicenseAgreedTo -string ${XCODEBETABUILD} 2>&1 | tee -a ${LOGFILE}
printf "Installing Beta Mobile Device development packages...
installer -pkg /Applications/Xcode-[bB]eta.app/Contents/Resources/Packages/MobileDevice.pkg -target / 2>&1 | tee -a ${LOGFILE}
installer -pkg /Applications/Xcode-[bB]eta.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg -target / 2>&1 | tee -a ${LOGFILE}
printf "$(date "+%Y-%m-%d %H:%M:%S") ${SCRIPTNAME} finished.
I'm having the same issue on my 10.10.5 VM, Xcode 7.2.1 still asks for additional components after running this script.
Xcode 7.3 beta seems to work again... lets hope that this is a temporary issue.
crap. I just encountered the additional components to install after putting xcode 7.2.1 on Self Service. Correct me if I'm wrong, but isn't xcode 7.3 only for OSX 10.11? We're still running 10.10 so I can't go to 7.3 if it has actually been fixed in that version. Can anyone figure out if there is an additional command we can add to the script to run so they are installed with the rest of the package instead of requiring admin rights to complete it?
The last bit of the install log in JSS indicates that the parts I DO have in the script installed fine, but there's obviously something else it needs.
Successfully installed Xcode 7.2.1.pkg.
[STEP 4 of 4]
Running script xcode_post_install.sh...
Script exit code: 0
Script result: installer: Package name is MobileDevice
Maybe, possibly, perhaps I have a workaround. Even though the script successfully calls for /Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg to install, I looked in /var/log/install.log and upon first launch of Xcode, this is the package it tries to install. Fine. I copied /Applications/Xcode.app/Contents/Resources/Packages/MobileDeviceDevelopment.pkg out to my desktop and then uploaded to my JSS via Casper Admin and added it to the Xcode 7.2.1 policy to run after the main xcode install package. I still have the script set to run "After" the packages install. I deleted Xcode.app from my test Mac and re-ran the updated policy via Self Service. When it finished, I launched Xcode and this time it did not prompt to install additional components. I need to test again on a different Mac to confirm.
EDIT.... no such luck on a fresh install nor on an upgrade install. DRAT!
