eap-tls automagic authentication on macOS 10.14
  • November 1, 2018
  • 14 views
I've an iMAC running macOS 10.14. I've configured it to use eap-tls to log into either our wired network or our wpa2-enterprise "eduroam" network.
Everything works just fine except thast you have to manually go into system preferences/ network and click connect
Is there any way of configuring 10.14 to automatically perform an eap-tls auth when system is rebooted ?
The system is a simple standalone device that needs automatic connection to either a wired or wifi 802.1x network
1 reply
  • November 1, 2018
Is your machine FileVault enabled ?
