Current setup is DEP having users login onsite with their LDAP credentials. I'm running into an issue where setup stalls if a user logs in with LDAP but then doesn't finish going through the setup wizard quickly the computer will go to sleep and when it wakes up shows a OS X login screen with the username "Setup Account" asking for a password. The only fix I've found is wiping the computer, reinstalling OS X and starting over. Has anyone run into this issue or found a fix?
MacBook setup issue when DEP w/ LDAP credentials entered
