9.81 Device App Updates causes apps to crash upon app software update
  • October 15, 2015
  • 34 replies
  • 139 views
We've deployed several apps via the Device based app deployment over the past couple of weeks. Today, I noticed on apps that had a software update yesterday, and therefore our server was set to auto update apps overnight, that these app installs are now crashing upon launch after the server . Our Canvas by instructure app as well as Notability were updated yesterday, and now those apps on devices that have apps installed via the device based deployment crash. These apps that are still assigned via User based model still function fine after the update.
I noticed this last week, but we had some other issues going on with the server, so I didn't think anymore about it until the next round of updates came out.
Deleting the app and reinstalling via Self Service fixes the issue.
Anyone else seeing this?
  • October 16, 2015
Yes, we are stil trying to identify the root cause, or the exact sequence that causes the issue because it is not happening on all devices. We have also found the same workaround to solve the issue (delete app and reinstall from self-service).
We noticed this with the Microsoft Office apps for iOS. We assume it was tied to the v14.x update last week.
  • October 23, 2015
We've had some rumblings about the Self Service > Updates tab not playing nicely with apps either. We have not done a full analysis yet, so I'm mostly just bumping this thread so we get any info that anyone else may add to it. So far our suggestion to folks is "don't update" because it just seems to wreak havoc.
  • October 27, 2015
We had a few apps - Google Docs and Google Sheets - that were installed with no Apple ID and when launched they would flash and disappear. They would not launch fully.
The resolution to this was to simply delete and reinstall. It seems like most times the app would appear in the "Updates" section, but also has appeared in the Self Service "App Store" section - simply reinstalling it from either section fixed the app so that it would launch.
  • October 28, 2015
We're having widespread issues with this as well. Google Apps experience this a lot as well as Book Creator. Unfortunately, Book Creator doesn't backup automatically like Google Apps, so we have students losing class work. Very frustrating.
  • October 28, 2015
I have seen apps crash when the user has installed the app, but then I have my JSS assign the same app to the device. Is this possibly related? Are your users installing the app and then the JSS is installing the update causing the problem?
I haven't had much time to play around with this, just throwing the idea out there.
  • November 5, 2015
We are seeing the same thing with Notability. Upwards of hundreds of devices having the crashing issue and students are losing homework because they do not setup auto-back (its so easy to do, not sure why it is so hard for them to do it).
Google Drive has also been doing the same thing, but that isn't an issue because its all stored in the cloud.
Notability support has been extremely unhelpful. Any help would be greatly appreciated!
  • November 10, 2015
Notability is crashing for us also. Management history shows as it getting updated --
Installed App List 11 minutes ago
Managed App Configuration 15 minutes ago
Certificate List 15 minutes ago
Profile List 15 minutes ago
Disable App Store 16 minutes ago
Profile List 16 minutes ago
Install App - Notability 16 minutes ago
The newest version of Notability is 5.90, but it shows on the iPad inventory as Notability being installed as 5.8.2. Try to launch the app and it immediately crashes.
  • November 13, 2015
We are seeing the same issue with apps set to install without Apple ID (auto install).
The app update never goes through and the app crashes upon opening. We are seeing this Lexia and Spelling city apps.
  • November 17, 2015
We have the same issue. Apps get a command to update, but the App doesn't update. After that the app will not load.
  • November 23, 2015
Any follow-up on this?
  • December 10, 2015
Yes...This needs to be addressed ASAP this is becoming a big problem for our devices. We have them set to auto update and are finding that apps are crashing on launch. Why is it always one step forward two steps back when all these new features are released. Very frustrating!
  • December 10, 2015
This is what I just got back from our account rep after opening an support ticket for this issue.
Sorry to hear about the issues with the apps!
Unfortunately, the post you saw on JAMFNation is accurate, and we have two separate defects up that it seems that you're running into. If you'd like to reference them in salesforce, the IDs of the defects are:
D-009790
D-009792
The first one explains that randomly throughout your apps, some just won't update at all. The second one explains the crashing of the apps after the forced update command fails from the first defect. Because of the huge impact of these defects, recently we have been suggesting to not use auto-updates at all until the issues are fixed. Also unfortunately, we are completely unsure of what is causing this. We don't know if it's Apple's device-based VPP and auto updates colliding, or if it's something from our software, but I can promise that we are actively working with Apple to figure it out and help one another resolve the issue.
In the meantime, there are a couple things we have to do. Firstly, uncheck all auto-updates that are set up in every app. It's too unpredictable right now, and the risk it runs is too high. The app just crashing unfortunately isn't the only bad thing that happens. As soon as the app crashes for the first time, all of the user data in the app is corrupted and unreadable. That brings me to the last thing we have to do. We need to unscope all of the apps from all devices (after making sure we have all of those auto update checkboxes unchecked), and then rescope them to force a re-install of all of them. If you have your students do an iCloud backup, you will be able to save user data for apps that haven't crashed yet, but for the ones that have crashed, it is too late. There isn't any way of predicting which apps it will happen on next, so it's best to just unscope all of them from all devices and then lay them back down. I would test it with one device first to make sure this is the solution that works.
Again, I apologize for the significant inconvenience this causes, and I promise that this issue is among the defects with the largest impact, and it is being looked at by Apple and by us with as high of a priority as we can give it. Let me know if you have any questions.
  • December 10, 2015
We are having the same issue. APPs that are affected include Google apps (gmail, docs, slides, sheets, drive), Book Creator, Keynote, Pages. This all happened when we pulled the apple ids from them.
russeller
  • December 10, 2015
If you use Sites, the problems get even worse. Another bug D-009880 if you are using Sites and have the same app push existing in more than one site if someone makes an adjustment or creates another app push of that same app, it'll install on all the ipads in all the sites scopes.
For example, I push Google Docs to Site A, it installs fine. Then the next day I push Google Docs (create new app entry) for Site B. It will also install on Site A and Site B. This is not cool.
  • January 13, 2016
We are still seeing this a lot with managed apps. Has anyone heard of any updates? Will the upcoming iOS 9.2.1 or 9.3 fix this or if it a Jamf issue? Any pointers on how to avoid this?
  • January 21, 2016
Any news on this? We have apps like Book Creator & Explain Everything that are crashing, losing student's data. I've already gone through every app and unchecked "auto-update" as well as shut it off in the JSS settings.
  • January 22, 2016
Wish I found this thread before I just provisioned 50 shared iPads! Getting lots of apps crashing as they open because of this. I've now turned off app auto updates but I'm now going to have to uninstall a load of apps and re-install them.
  • January 22, 2016
Do the apps work fine if the auto update is turned off?
  • January 22, 2016
Any updates on this? Now that 9.2.1 is out... Or will it require a JAMF update?
  • January 22, 2016
@St0rMl0rD Even if you turn off auto update you still need to re-install the affected apps. The issue won't re-occur if you've turned off auto update after you've re-installed the app.
@snourse We had some apps with this issue and updated the iPad to 9.2.1 but didn't fix it. The only fix we have it to re-install the app. I guess the app update feature needs fixing within JSS (other mdms?).
Edit: Just pointing out that we're on JSS 9.82 and still have this issue.
  • February 17, 2016
Has this been resolved yet? i have lots of crashing apps that fix as soon as i update them on the JSS - wish i could turn on auto update!
  • February 17, 2016
@anitasmith AFAIK it unfortunately hasn't :(
  • February 26, 2016
We've run into the same issue - turning off auto-update is not a viable option in our environment. Too many carts!
  • February 29, 2016
Following this post. Having the same issue in my environment.
  • February 29, 2016
I have experienced the same issue. I had to delete the apps, and then then re-installed automatically but a huge problem. Experienced it with Google Apps, Microsoft Apps, and Adobe Apps to name a few.
