Errors with Autopkg(r)
  • October 29, 2014
  • 5 replies
  • 59 views
After being at JNUC I was inspired by Autopkgr and decided to setup Google and Firefox to auto update.
Day 1, no problems. Day 2, crap what did I do?
I removed the policies and smart groups (manually) from the JSS. Now when I run check apps now it downloads puts the file on my JDS and then blinks away and never recreates the policy or smart groups.
When I ran it from the command line I get this error about an object conflict I can not for the life of me find. Any help would awesome.
Traceback (most recent call last): File "/usr/local/bin/autopkg", line 1334, in <module> sys.exit(main(sys.argv)) File "/usr/local/bin/autopkg", line 1328, in main exit(subcommands[verb]['function'](argv)) File "/usr/local/bin/autopkg", line 1152, in run_recipes autopackager.process(recipe) File "/Library/AutoPkg/autopkglib/init.py", line 466, in process self.env = processor.process() File "/Library/AutoPkg/autopkglib/init.py", line 295, in process self.main() File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 596, in main self.groups = self.handle_groups() File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 345, in handle_groups computer_group = self._add_or_update_smart_group(group) File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 374, in _add_or_update_smart_group update_env="jss_group_updated", added_env="jss_group_added") File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 433, in _update_or_create_new recipe_object.save() File "/Library/Python/2.7/site-packages/jss/jss.py", line 609, in save raise JSSPostError("Object Conflict! If trying to post a "
jss.jss.JSSPostError: Object Conflict! If trying to post a new object, look for name conflict and delete.
  • October 29, 2014
When AutoPkgr is open, hold the Option key on your keyboard and click the icon in the top task bar. Click Verbose Logs to turn it on. Open Console and scroll to the bottom of All Messages. Watch for the Console after clicking Check Now and copy/paste the whole thing from the first AutoPkgr task message after hitting the Check Now button to the last.
Also check out this comment on another issue I had with AutoPkgr about a verbose flag for Autopkg binary: https://github.com/lindegroup/autopkgr/issues/175#issuecomment-60855209
donmontalvo
Forum|alt.badge.img+36
  • October 29, 2014
19:35:10] <@frogor> donmontalvo: JAMF user should file a bug report at [https://github.com/sheagcraig/jss-autopkg-addon/issues [19:40:16] <donmontalvo> froger: Thanks, I'll post that link if it's OK [19:41:03] <@frogor> donmontalvo: By all means. If you use my name, feel free to use the 'frogor' spelling ;) (many IRC clients also have tab-complete for name completion :)) [19:41:17] <donmontalvo> LOL...cool, will do :D
  • October 30, 2014
Here is the verbose log file. I will take a look at your thread over at Github also.
10/29/14 9:18:51.576 PM AutoPkgr[391]: [DEBUG] Completed AutoPkg Task: /usr/bin/python /usr/local/bin/autopkg version
10/29/14 9:18:52.256 PM AutoPkgr[391]: (1/2) Processing GoogleChrome.jss...
10/29/14 9:18:52.866 PM AppleFileServer[590]: GetAttrListStandardVolumeInfo: getattrlist failed with errno: 2!
10/29/14 9:18:52.000 PM kernel[0]: hfs: summary table not allowed on FS with block size of 2048
10/29/14 9:18:52.000 PM kernel[0]: hfs: could not initialize summary table for Google Chrome
10/29/14 9:18:52.000 PM kernel[0]: hfs: mounted Google Chrome on device disk4s2
10/29/14 9:18:53.366 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:18:53.366 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:18:53.366 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:18:53.787 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:18:53.787 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:18:53.787 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:18:53.000 PM kernel[0]: hfs: unmount initiated on Google Chrome on device disk4s2
10/29/14 9:18:53.965 PM AppleFileServer[590]: GetAttrListStandardVolumeInfo: getattrlist failed with errno: 2!
10/29/14 9:18:54.321 PM AppleFileServer[590]: GetAttrListStandardVolumeInfo: getattrlist failed with errno: 2!
10/29/14 9:18:54.000 PM kernel[0]: hfs: summary table not allowed on FS with block size of 2048
10/29/14 9:18:54.000 PM kernel[0]: hfs: could not initialize summary table for Google Chrome
10/29/14 9:18:54.000 PM kernel[0]: hfs: mounted Google Chrome on device disk4s2
10/29/14 9:18:54.355 PM com.apple.launchd[1]: (com.apple.disks.smart.status) Throttling respawn: Will start in 9 seconds
10/29/14 9:18:54.391 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:18:54.391 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:18:54.391 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:18:54.794 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:18:54.794 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:18:54.794 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:18:55.204 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:18:55.205 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:18:55.205 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:18:55.612 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:18:55.612 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:18:55.612 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:19:16.000 PM kernel[0]: hfs: unmount initiated on Google Chrome on device disk4s2
10/29/14 9:19:16.312 PM AppleFileServer[590]: GetAttrListStandardVolumeInfo: getattrlist failed with errno: 2!
10/29/14 9:19:16.769 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:19:16.769 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:19:16.770 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:19:17.200 PM sharingd[414]: GetStatus: connecting to self not allowed
10/29/14 9:19:17.200 PM sharingd[414]: ERROR: AFP_GetServerInfo - connect failed 62
10/29/14 9:19:17.200 PM sharingd[414]: netfs_GetServerInfo returned 62
10/29/14 9:19:17.233 PM AutoPkgr[391]: [DEBUG] (FULL AUTOPKG TRACEBACK) Traceback (most recent call last): File "/usr/local/bin/autopkg", line 1334, in <module> sys.exit(main(sys.argv)) File "/usr/local/bin/autopkg", line 1328, in main exit(subcommands[verb]['function'](argv)) File "/usr/local/bin/autopkg", line 1152, in run_recipes autopackager.process(recipe) File "/Library/AutoPkg/autopkglib/init.py", line 466, in process self.env = processor.process() File "/Library/AutoPkg/autopkglib/init.py", line 295, in process self.main() File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 596, in main self.groups = self.handle_groups() File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 345, in handle_groups computer_group = self._add_or_update_smart_group(group) File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 374, in _add_or_update_smart_group update_env="jss_group_updated", added_env="jss_group_added") File "/Library/AutoPkg/autopkglib/JSSImporter.py", line 433, in _update_or_create_new recipe_object.save() File "/Library/Python/2.7/site-packages/jss/jss.py", line 609, in save raise JSSPostError("Object Conflict! If trying to post a "
10/29/14 9:19:17.234 PM AutoPkgr[391]: [DEBUG] Completed AutoPkg Task: /usr/bin/python /usr/local/bin/autopkg run --recipe-list /Users/macadmin/Library/Application Support/AutoPkgr/recipe_list.txt --report-plist /var/folders/9y/jw4tm_ld6f55pc9p31_d64q80000gn/T/76E71809-5D26-478C-B358-B1B349F0A99A-391-000018695A48DCC6
  • October 30, 2014
Just curious, what if you try another package. Maybe something you've never had? That way you can be sure you are not have any conflicts. If you take the error message literally, then you have a conflict going on. But sometimes, something else makes a script think it is one thing when it is really another. It looks like it has to do with a smart group object. It cannot save it. Permissions issue? And I don't know what to make of all of the errors above.
I am just about to go down this road myself. I've got Autopkg setup and am testing using it for getting packages. Next step will be to add the jss-addon and test that out.
  • November 4, 2014
So I tried 2 different packages and are getting no valid receive. Which is weird because when I browse to the folder it is looking in it is there.
11/4/14 3:23:20.419 PM AutoPkgr[493]: [DEBUG] Error [1] Error creating OverrideDescription file Could not find parent recipe for Compressor.jss
No valid recipe found for Compressor.jss
Dir(s) searched: .:~/Library/AutoPkg/Recipes:/Library/AutoPkg/Recipes:/Users/macadmin/Library/AutoPkg/RecipeRepos/com.github.autopkg.recipes:/Users/macadmin/Library/AutoPkg/RecipeRepos/com.github.sheagcraig.jss-recipes:/Users/macadmin/Library/AutoPkg/RecipeRepos/com.github.sheagcraig.jss-recipes
11/4/14 3:23:20.419 PM AutoPkgr[493]: Error creating OverrideDescription file
11/4/14 3:23:20.420 PM AutoPkgr[493]: [DEBUG] Completed AutoPkg Task: /usr/bin/python /usr/local/bin/autopkg make-override Compressor.jss
