Reinstall a clean macOS with One Button
  • June 14, 2018
  • 6 replies
  • 31 views
Hi Admins, we are testing the https://www.jamf.com/blog/reinstall-a-clean-macos-with-one-button/
After the process and we decided to leave the install macOS High Sierra.app in /Applications? How does one protect the user from clicking/running it? Is there a way to hide it from the Users like make it a hidden file?
  • June 14, 2018
change the permissions so only root can see it, or place it else where which is what we do. All our builds have a Management folder which has subfolders for various things we can use like graphics, Documents and Deployments which is where we place the OS installer.
like this /Library/corpnamemanagement/Deployments.
davidacland
  • June 14, 2018
You can use chflags hidden /Applications/appname.app to hide things like that. In recent OSes, it doesn't work on built-in apps (you get a "Operation not permitted" error), but might still work for Install macOS.app.
(use chflags nohidden... to make items visible again)
  • June 15, 2018
Hi, when I go by the blog post and try it on a test machine, it does not do anything. It has the most current High Sierra.app from the app store. When I go into Terminal it brings back an error code: 800.
Any ideas?
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • June 15, 2018
@niacobelli, I believe that error 800 indicates the drive may not be formatted as APFS. To verify, open Disk Utility and you'll find it's either HFS+ (not supported with this command) or APFS.
  • June 18, 2018
@davidacland after hiding the install macOS using chflags, we should be able to use the script right since it is being run by root? sorry, I don't have the means to test right now. Thanks Sir!
davidacland
  • June 18, 2018
Yes, the script will still work as chflags only hides the app from the GUI. Command-line is unaffected.
