Hey!
I have just ended my trial weeks for JAMF and have been fiddling around with smart groups and policies mostly. One example I was curious about is how to build smart-groups the most efficient way possible to reduce overhead.
Example: Users need SPSS 24 to be installed, and needs to have the latest version.
Should I create one smart-groups for scoping up users that dont have the software installed at all, and another groups for users that HAVE the software installed but to install the latest version and so on? Or should I group those criteria in just one smart-group?
