Between version 7.10.x and 7.12.x, the location the binary has changed. Current versions install in /usr/local/sbin and prior versions installed in /usr/sbin
This EA script will report on the version for either location. It's based on a prior EA available from JAMFNATION.
# REFERENCES:
# https://jamfnation.jamfsoftware.com/viewProductFile.html?fid=800
# Depending on the version installed, the binary could be in either /usr/local/sbin or /usr/sbin
if [[ -e "/usr/local/sbin/enosxintel" ]]; then
encaseVersion=$(/usr/local/sbin/enosxintel -help 2> /dev/null | grep enosxintel | head -1 | awk '{print $2}')
elif [[ -e "/usr/sbin/enosxintel" ]]; then
encaseVersion=$(/usr/sbin/enosxintel -help 2> /dev/null | grep enosxintel | head -1 | awk '{print $2}')
elif [[ ! -e "/usr/local/sbin/enosxintel" ]] && [[ ! -e "/usr/sbin/enosxintel" ]]; then
encaseVersion=Not Installed
echo "<result>$encaseVersion</result>"
Be the first to reply!
