Dear JSS Guru's,
We have about 70 managed ipads which run 1 profile which has web clips and nothing else. As of late im traying to figure out why when i want to add and remove web clips from the config it doesnt update all the manged ipads when on wifi correcty once settings applied and all iPads.
This wasnt an issue for awhile until the customers wanted to keep changing web clips.
- Blank push appears fine
- Cant remove old webclips wont allow them to delete
- Old profile config wont update on the fly via push service correctly
- Used to work within seconds of change
Any thoughts would be cool.
Cheers.
Lyndon Cook
Be the first to reply!
