Is anyone successfully using an extension attribute to track the thaw or frozen state of imacs running DF version 5? Since upgrading our labs to DF 5 for mac the templates included in the jamf nation knowledge base and in the extension attribute page inside of the computer management tab in Casper 9.0 do not work anymore. From what I can there has been some sort of syntax change but cant tell what exactly is needed to get things working right.
Page 1 / 1
I don't know if you managed to get this to work or not, but I just made a new script (first JSS script for me!)
# Queries Deep Freeze status and returns either Frozen, Thawed, or Deep Freeze Not Installed
# Replace password and user below with your Deep Freeze user and password
DFStatus=$(DFXPSWD=password /Library/Application Support/Faronics/Deep Freeze/deepfreeze -u user -p status -x | grep -A1 "<key>bootHow</key>"| awk '{gsub("<key>bootHow</key>", "");print}'| awk '{gsub("<integer>", "");print}' | awk '{gsub("</integer>", "");print}')
if [ ! -f /Library/Application Support/Faronics/Deep Freeze/deepfreeze ]; then
echo "<result>DeepFreeze not installed.</result>"
if [ "$DFStatus" -eq "0" ]; then
echo "<result>Frozen</result>"
if [ "$DFStatus" -eq "1" ] || [ "$DFStatus" -eq "2" ] ; then
echo "<result>Thawed</result>"
exit
I've updated the script for Deep Freeze 7!
DFStatus=$( /usr/local/bin/deepfreeze status )
DFStatus=$(echo $DFStatus|cut -c15-20)
echo "Deep Freeze Status is: "$DFStatus
if [ ! -f /usr/local/bin/deepfreeze ]; then
if [ "$DFStatus" = "Frozen" ]; then
if [ "$DFStatus" = "Thawed" ]; then
exit
