Smart Configurations and partitions.
  • August 3, 2012
  • 16 views
We've got a base Mac image that we use for all our machines. However, We have two images, one with Windows as a VM, and one with Windows as a separate partition. So the only difference between them is Parallels, and a Winclone file.
What's the easiest way to set this up through configurations in Casper Admin? I had a Parent Configuration with all the similar software, and then two smart configurations with the differing software, which would work, but Smart Configurations don't allow additional partitions, so the Windows in a partition smart configuration won't work.
Is there a way Casper Admin can do this, or should I put in a feature request?
1 reply
AlanSmith
  • April 11, 2013
Have just come across a similar issue, whereby the pre-stage imaging using a Smart Config doesn't 'see' the partitioning specified in the parent config.
We partition all our Macs to give the users a place to store their data that isn't on the boot partition, so less chance of losing files if the machine has to be re-imaged.
I would put in a feature request Joeseph, in the meantime, I think 2 separate Parent Configurations are going to be the way around this.
