10.3 iOS on Device - Allow Cellular Modification not locking now
  • March 29, 2017
  • 0 replies
  • 3 views
I am upgrading some devices to 10.3 and using JSS 9.97.1483031164 and have noticed even though I have "modify cellular data" option unchecked I am still able to modify this on the device.
It was being locked on 10.2.1 devices. Is anyone else seeing this? Also is there going to be an other anomalies that 10.3 might cause if we are not running the new JSS with 10.3 support?
Seems like a majority of the new 10.3 devices I am testing are not getting the policy either at all or it takes a push or reset of the device as well.
Any other thoughts on 10.3 so far using non 9.98 JSS?
Thanks
