- duplicate post that came out of moderation queue, this can be removed; see here
having the same issue here.
Hey all,
We’re aware of this issue and have it filed under PI-000867.
It happens because the EBookHelper doesn't differentiate between inHouse and AppStore type, so when the blank value for the itunes_id in iBooks/eBooks happens it’s causing Java to error with the String Index out of Range, which is what the -1 is.
We’ve only seen it happen when Populate Purchased VPP Content is enabled in Settings > Global > VPP > Content.
The error itself is harmless and can be ignored.
If you'd rather not see the error in the logs, the workaround is to disable Populate Purchased VPP Content in Settings > Global > VPP > Content.
If you have further questions or would like to get a case created to be attached to PI-000867, please get in touch with Support either by giving them a call, sending an e-mail to support@jamf.com, or by using the My Support section of Jamf Nation.
Amanda Wulff
Jamf Support
This isn't listed as Known Issue (anymore) but it still happens in our instance - does anyone have a clue? Disabling Auto Population isn't an Option for us.
