Suggestion for documentation
  • October 22, 2014
  • 0 replies
  • 1 view
I would just like to make a small suggestion. In the documentation walking you through the installation and configuration of the server. Please change where it references Java 1.6 or 1.7 to Java JDK 1.6 or 1.7.
It may seem like a small change but I was a tad confused and installed normal Java. Again it was a rookie mistake on my part but it would add some better clarification.
