Howdy,
I need to rebuild my base OS image and would appreciate your opinion on what
machine I should build it with. Currently in my lab, I have a MacPro 2008,
MacPro 2010, MacAir 2010, and a MacBook Pro 2011. I'm thinking of using the
MacBook Pro 2011 since it's what the majority of new builds will be running
on, but aren't sure if basing my image on a certain hardware profile will
affect it differently then say a MacPro.
Any advice or wisdom would be appreciated.
thanks
Dave Simon
Director, Media Engineering and Operations
T +1.415.808.3594 | F +1.415.808.3535 | C +1.617.908.5043
600 Harrison St € San Francisco, CA € 94107
PRN | media where & when it matters
