how can we remove browser apps from student ipad
  • April 29, 2019
  • 18 views
We need to remove all browser apps from a student ipad, creating a configuration profile where the student can only have access to google classroom and certain school apps. Can anyone help me with this???
  • April 29, 2019
There is a Configuration Profile that lets you define which apps are allowed on a device. You can either whitelist or blacklist apps. The profile is called 'Restrictions'. What is a bit confusing is that the settings for restricting apps is under 'iOS and tvOS', not simply under 'iOS'.
Hope this helps.
  • April 29, 2019
Ok great I will give it a try...
