Find / Email notifications on reboots
  • October 17, 2015
  • 4 views
Hey All,
Just wanted to know if there is an easy way to find machines that reboot at a certain time period without pouring thru logs on each machine I have in a Static Group.
Thanks everyone !
Best answer by Johnny_Kim
Test this extension attribute (Its 2am when I wrote this EA). Output will be in 24hr format, and when creating a smart group, you may have to add multiple criteria depending on what you are trying to achieve.
#! /bin/sh
lastreboot=`last -1 reboot | awk '{ print $6}'`
echo "<result>$lastreboot</result>"
  • October 18, 2015
#! /bin/sh
  • October 22, 2015
TY!
