We have an environment where many people have laptops and almost never connect using a wire. Because of this the mounted SMB home directory falls off and don't get mounted again because its a login script for AD. I'd like to provide the users with a script that would mount their home directory for them.
Does anyone know of a way to manually get the home directory info from AD and mount it?
It would be easy if we had only on server where home directories were located, but we have several, and the only way to know who's is where is to get the path from AD.
thanks!
