Autorun Question: "Automatically Image this Computer..."
  • June 25, 2012
  • 23 views
What is the exact behavior of the "Automatically Image this Computer the next time Casper Imaging is launched" checkbox? Is it a toggle, or does it reset after the imaging takes place the first time after it is checked?
Best answer by frozenarse
It remains selected even after imaging is complete.
  • June 25, 2012
  • June 25, 2012
That's interesting. I never knew it worked that way. I honestly never used Auto-run much since I never managed a lab environment which is what its best used for. I always assumed that option worked one time after it was checked and then reset itself. The wording is a bit confusing since it states "the next time Casper Imaging is launched" It should probably say "each time Casper Imaging is launched" if that's actually how it works.
