Chrome Dock item missing in Casper Admin
  • February 14, 2013
  • 6 replies
  • 19 views
Casper Admin is not showing the dock item for Google Chrome. I have tried running Casper Admin on multiple Macs with Chrome installed with no luck. Ctrl-click - options - leave in dock did not make a difference. Does anyone out there know how to get all dock items to show up, or perhaps a workaround?
Best answer by bentoms
Run: ```
killall Dock
``` then open Casper admin.
That's what I've often had to do.
  • February 14, 2013
That's strange. You sure its not already added in? Actually I don't think Dock items are the same as printers, but might be a good idea to double check.
Keep in mind I think Casper Admin reads from the dock plist file, so you can run something like this to make sure Chrome is actually showing up in the plist-
defaults read com.apple.dock | grep file-label
That should output a list of the items the Dock sees in its permanent list by their labels. You can also substitute file-label with bundle-identifier as well for another view. Make sure it shows up there.
bentoms
Forum|alt.badge.img+35
  • February 14, 2013
Run: ```
killall Dock
donmontalvo
Forum|alt.badge.img+36
  • February 15, 2013
@bentoms wrote:
Run:
killall Dock
then open Casper admin. That's what I've often had to do.
Wow, that works great - maybe a minor bug in Casper Admin...where it should do this for you (or is but not reliably)? :)
Don
  • February 15, 2013
Thanks Bentoms,
killall Dock worked beautifully. I can see all the dock items in Casper Admin.
akseez
  • February 27, 2014
I'm having the same problem. I've checked the com.apple.dock plist and it's listed there. I have also tried running 'killall Dock' but Chrome still doesn't show up in the Add Dock Items list in Casper Admin. I've noticed that Safari, Screen Sharing, and System Preferences, which are also in my dock, don't show up. I've tried this on multiple Macs with the same issue. I'm running Casper Admin 9.24 on OS X 10.9.2.
akseez
  • February 27, 2014
Oops. Someone else in our organization had already added it that I was unaware of.
