I am having issues with the resource kit script to join a machine to a wireless network. I've used the script in the past with a mixture of old Airport and cisco access points. We just installed campus wide cisco wireless and the script in the kit does not seem to work. I can join a machine manually with no issues.
I am looking to script joining a machine to a closed WPA2 personal network. Anyone happen to know why the resource kit script is not working? or have something similar hanging around that will work? the thought of joining a couple hundred laptops to this new network by hand is depressing me :-)
thanks
Man is a credulous animal, and must believe something; in the absence of good grounds for belief, he will be satisfied with bad ones.
- Bertrand Russell
Eric Young
eyoung at thayer.org
